How to you guy endcaps so perfectly?
Discussion in 'Archived Threads 2001-2004' started by Andrew S, Jan 25, 2003.
  1. Andrew S
    Andrew S Stunt Coordinator
    Sep 30, 2001
    214
    I eventually want to build a shiva sonosub and I've browsed the various sonosub pages, and still can't figure out how you cut the endcaps so EXACT that it fits just inside the sonotube. Does anyone have any tricks as to how you do this?
    Andrew
    Edit: Forgive the missing "cut" in the title.
  2. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
  3. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    Find the true circumference of the sonotube (use a string, wrap it around, measure the string for the circumference, and then determine radius of the sonotube using simple geometry:
    circumference = 2*pi*radius, solve for radius:
    radius = circumference/(2*pi) (use pi = 3.14159)
    That gives you the outer radius of the sonotube. Measure the thickness of the sonotube, and subtract that from the radius. You might want to add just a smidge, like 1/8" to the final radius.
    Once you have the radius, you'll need to use a circle jig that allows you to set the radius for the router cut to the exact length.
    It's better to cut the endcap too wide, and then re-route to a slightly smaller diameter, else your endcap will be too small and fall through the hole.
    If you're really unsure, first route the endcap using the original radius, and then whittle/route down by reducing the radius by just under the thickness of the sonotube material for a tight fit. Also, you may need to use a rubber mallet to get that tight fit, but don't split the sonotube material with an endcap that's simply too wide.
  4. Jonathan_D
    Jonathan_D Stunt Coordinator
    Jan 22, 2003
    142
    Darn, that's why I can't get my circles perfect, I don't have any patients only patience! I guess I need to go to the local doctor's office and get me some. [​IMG]
  5. Frank Carter
    Frank Carter Screenwriter
    Mar 12, 2002
    1,187
  6. Andrew S
    Sep 30, 2001
    214
    Thanks for the help. I don't even have a router or jigsaw at the moment, so I guess that'll be my next step [​IMG]
    Andrew
  7. Bryan Michael
    Bryan Michael Supporting Actor
    Mar 2, 2002
    564
    i took the tube of scrap draw a ciecle and cut then take a round over bit to the edge to fot the endcap in the tube
  8. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    why don't you guys double up the MDF making a 1.5" piece then route the end cap, that is the same circumference as the sono tube, and then take the thickness of the sono tube off but only going 3/4 deep, so it will be like a lid that will just sit on it, and if you cut it too small, then just seal it up with a few thin layers of silcone around the rim and on the cap, for a nice fit that will sit on the tube
  9. Patrick Sun
    Jun 30, 1999
    38,749
    480
    9,110
    I still prefer to make the inner endcap as tight fitting as possible, so I do the inner endcap and test for fit and then I laminate it to a wider endcap. I've done this with all 3 of my Sunosubs (anyone who's curious, please check my DIY projects page below in my signature).
  10. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    Sonotube tends to be less than a perfect circle before the endcaps are installed.
    I use no less than 1.5" thick caps, cut with a Jasper jig. A round-over bit is used to 'ease' the inside edge of the endcap. I install the caps by 'greasing' the edge with siliconized acrylic caulk (slippery when wet, then acts as a glue when it dries).
    [​IMG]
    Then insert the cap in the center of the tube, parallel to the sided walls of tube. Rotate it into position with a dead-blow hammer. Then wipe of the excess caulk.
    [​IMG]
    Nice snug fit
    [​IMG]
