Leo_P
- May 13, 2002
First off, my system includes a P4 @2.4GHz with XP Pro and a ATI AIW Radeon 8500.
I'm seriously considering getting a Phillips HDTV that has an RGB input.
What I'd like to do is install an MIT MyHD card and use that for OTA material via RGB.
Now comes the tricky part. I'd also like to use my PC as a progressive DVD player. It seems I could run the VGA out from the AIW 8500 to the TV, but how would I use my brand-new 17" LCD monitor? The Radeon 8500 does support a monitor and a TV, but the output options are either DVI (which I'm using with a DVI to VGA adapter to my monitor) or composite. I can't use composite to send a progressive signal, so now what?
How is everybody else doing it? Am I better off just getting a progressive DVD player?
