Anyone have a DIY or link so I can use a flat panel computer monitor as an HDTV. Flat panel computer monitors are much cheaper that LCD or plasma TVs. TIA
With what are you trying to feed it? You could always just use an HTPC source, for instance. If you're trying to feed it from consumer stuff, you may need some signal adapters since monitors want RGB (via a VGA plug) and not much consumer equipment deals in RGB. RGB is mainly in the professional realms, and from HTPCs...
