how to tweak old mirage subwoofer
Discussion in 'Speakers & Subwoofers' started by Ron_Yeoh, Jan 18, 2005.
  1. Ron_Yeoh
    Ron_Yeoh Extra
    Mar 10, 2004
    19
    Hi all
    Am using a 5 yr old, big and powerful Mirage subwoofer in my home theatre system but am finding the bass flabby...what can I do to tighten it up? Can't remember what the knobs at the back do..there's one for level and one for output. THanks
    Ron
  2. joseFMJ
    joseFMJ Stunt Coordinator
    Nov 12, 2004
    58
    Check the condition of the cone surround, make sure its in good condition. The 'knobs' are for balancing the sub with any other speakers connected to the sub. Try lowering the INPUT level. If the cone is ok, try moving it away from corners. If none of those pan out, the amp in the sub might be suspect. While the warranty on a sub might be 5 years, usually the built in amp has a 1-2year warranty.
  3. Ron_Yeoh
    Ron_Yeoh Extra
    Mar 10, 2004
    19
    thanks jose will try and see...
  4. Morgan_
    Morgan_ Stunt Coordinator
    Jan 9, 2005
    61
    I'd pull the driver out, and take some measurements of your cut out, you can always enlarge it a little if you have to, and go to partsexpress.com and maybe put a titanic driver in there and watch that sub come alive again!! Most OEM drivers are not the greatest, with a new driver capable of more excursion and tightness, I bet you could really juice up that sub[​IMG] [​IMG]
  5. Thomas Dekany
    Jan 6, 2005
    38
    may sound stupid, but is the sub calibrated? If not get a SPL meter from Radio Shack.
    Could you move it right behind the listening position?
    These are my suggestions if the sub is in "working" condition.
