GetGray
Grip
- Sep 28, 2004
Greetings:
I have a spiffy almost new HGS18 I bought used from a pretty good source. I am interested in testing it just to be sure it's working properly after shipping. Is there an easy way I can do this? This is my first sub and I have Avia, VE, and DVE, and a RS SPL, but from my limited understanding, Avia seems more oriented toward calibration that a plain old test. Is there some simple procedure one could recommend to run the sub through it's paces and test that it's functioning properly, or probably OK? I do have the ability to create CD's and I know where to at least get some test tones (snapbug's) if that's any help.
Right now the sub is in my huge wide open unfinished basement and it's not putting off any jaw dropping pantsleg flapping bass on some DVD's I have tried. I hadn't expected too much but did expect a little more. I figured the space size might be a partial culprit for that.
I'm not looking for detailed tuning and setup, just a warm fuzzy feelng that the sub is OK, dosent' hav a messed up amp or driver, and will likely work properly once I can get it into it's new (smaller) space and properly tweak it.
Scott
Scott
