How to take screen captures?
Discussion in 'DVD' started by Scott Leopold, Nov 11, 2003.
  1. Scott Leopold
    Scott Leopold Supporting Actor
    Nov 21, 2001
    711
    I've spent most of this evening checking here and elsewhere for a way to take screen captures that won't require me buying any new software, but haven't had any luck so far. Any help or advice would be appreciated.
  2. StevenFC
    StevenFC Second Unit
    Aug 23, 2003
    481
    PowerDVD
    Couldn't be easier.
  3. Ricardo C
    Ricardo C Producer
    Feb 14, 2002
    5,059
    If you want DVD caps, any decent software player will have a built-in capture option. If you're talking about other overlay applications, I'm afraid that the cheapest you'll find is HyperSnap. No freeware that I know of will let you make overlay captures.
  4. Tom_Bechet
    Tom_Bechet Second Unit
    May 20, 2002
    283
    Steven, technically you have to pay for Powerdvd. But I found it to be the best DVD software around.
    Scott: I`m sorry but I only use Powerdvd and it ahs that feature, very useful, but otherwise I`m out of ideas.
    you could try a printscreen and paste it into pain or so but I`m not sure if that works.
    soory
  5. Scott Leopold
    Nov 21, 2001
    711
    I tried downloading Windows Media Player 9 last night, and found out after I had downloaded it that you can only play DVD's on it if you're running XP. Does anyone know of any reliable plugins or anything else that adds DVD capability to WMP9 on a Win98 machine?
  6. Lars_J
    Lars_J Stunt Coordinator
    Oct 23, 2002
    200
    Hypersnap rocks. It lets you capture the original 720*480 source, without any blending or stretching.
