HOW TO surround sound speaker wiring (1 Viewer)
Babette
my set up:
-cable box
-emerson vcr/dvd
-RCA tru flat television - connected to the above through cable via cable in to box, out/in to vcr/dvd, out to tv
-pro dynamics spl 3000 home theatre series subwoofer/amp with one center and 4 surround speakers
my dilemma:
I have the amp receiving/projecting sound via cable connect to tv monitor out with settings on tv as Sound-enhanced,SAP, Audio Output-fixed, and int. speakers set "for the tv to be center" - on the amp there are four typical connects for the speaker wire - 2 labeled "in" and 2 labeled "out" - can any one advise as to which wire should go where for sound to the smaller speakers?
JamesCB
You bought these from the back of a white van, didn't you?
Without a surround receiver, you are shit out of luck. These are not powered.
James
Babette
that's funny! but my boyfriend gave them to me... maybe he saw the white van, I don't know... I just want to get them to work (laughing) - so I need a receiver then?
Ted Lee
can you tell james is from new york? :rolleyes:;)
yes, babette, it sounds like you need a receiver, but you mention the word "amp", so i'm not sure what you have.
just to confirm, you have a total of 5 speakers (plus a sub) - is that correct? also, do you know if the sub is powered or not (if there is a power-cable coming out of the sub, then it's powered).
in any case, to get these to work you need to hook them up to a ht receiver (one that is capable of reproducing 5.1 surround sound). just about every ht receiver can do this now. you can get a decent one for about 200 bucks these days.
once you have the receiver, you can actually hook up all your other components to it as well.
Logos1204
