can someone answer this
Dec 22, 2002 #2 of 7 zane Stunt Coordinator Joined Oct 21, 2002 Messages 104 what the hell it deleted my original post, i was wonder if i have to stuff the tempest sealed enclosure any way special or if i just loosely put it in, i was wondering if i'm suppose to keep it away from the driver for heat reasons
Dec 22, 2002 #3 of 7 Patrick Sun Senior HTF Member Joined Jun 30, 1999 Messages 39,669 Yup, fluff up the stuffing material, and try to keep it out of the driver basket areas.
Dec 23, 2002 #4 of 7 ThomasW Senior HTF Member Joined Nov 6, 1999 Messages 2,282 Use 0.5-1.5 lbs/cu ft HERE's some more info
Dec 23, 2002 #5 of 7 Mark Fitzsimmons Supporting Actor Joined Aug 18, 2001 Messages 539 I put two pounds into my sealed tempest (122L) Just put it in there, try to evenly distrubute it.
Dec 26, 2002 #6 of 7 TimForman Supporting Actor Joined Dec 4, 2002 Messages 847 I used a little spray on adhesive on the inner walls to keep the polyfil from falling in my down firing MidQ box.
Dec 26, 2002 #7 of 7 TimForman Supporting Actor Joined Dec 4, 2002 Messages 847 I should've added that other than the spray on adhesive I just placed it loosely into the box.
