How to stuff a downfiring sub?
Discussion in 'Home Theater Projects' started by Dave Poehlman, Jul 8, 2003.
  1. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    Since my Shiva Redux is coming along slowly, I am at the point to start considering stuffing it. But, since the driver and amp are at the bottom of the enclosure, I don't want my stuffing coming in direct contact with them.
    How have you guys/gals been stuffing your downfiring sonotubes and the like?
    I thought about using some sort of netting or possibly grille cloth to suspend my stuffing over the driver... however, I'm also concerned with how the cloth/netting might affect airflow.
    How are you keeping it up?
  2. TimForman
    TimForman Supporting Actor
    Dec 4, 2002
    847
  3. MichaelAngelo
    MichaelAngelo Stunt Coordinator
    Oct 22, 2002
    137
    Dave,
    I used speaker grille cloth. It's supposed to be acoustically transparent right? So I cut a piece and glued it above the driver, as a net, to hold stuffing off the drivers.
    HTH
  4. Richard DeCius
    Richard DeCius Auditioning
    Jan 11, 2003
    2
    Hi. I just recently built a sealed enclosure for my Tempest subwoofer. I bought a can of 3M spray on glue and sprayed one space at a time and then put a layer of acoustastuff over the glued area until all the walls and ceiling were covered. I have been using it for a month now and none of it has come off at all.
    You might think about giving that a try.
    Hope that helps.
