how to round corners? whats the correct way?
Discussion in 'Archived Threads 2001-2004' started by Wendell, Jan 2, 2003.
  1. Wendell
    Wendell Stunt Coordinator
    Jul 23, 2002
    96
    Can you help me on how to round corners? I'm afraid I might round it off too much and the cabinet would be weakended?
  2. Chris Carswell
    Chris Carswell Supporting Actor
    Mar 5, 2002
    598
    Don't worry about that part. Unless your cut is super deep or super long you will be fine.
    I will say to get any sonic benefits or to lay veneer you will need at least a 3/4" roundover. If this is not the reason why you are doing this or if your router can't accept 1/2" shank bits then this is a moot point anyway.
    If you just want to add a nice look to your speakers then go get yourself a 1/2" roundover bit with ball bearing guides. This is important. Good luck [​IMG]
    [​IMG]
  3. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    If you're using 10 mil paper backed veneer then a 1/2" roundover will work fine. If you want to use something like the NBL veneer then you'll want at least a 3/4" roundover. I do know a guy that's used the NBL stuff with a 1/2" roundover, but you have to wet it down pretty good to get it to bend without splitting.
  4. matt.r.w
    matt.r.w Auditioning
    Dec 18, 2002
    8
    Hi Guys,
    I've noticed some people rounding over the non joint edges of their braces. Can anyone tell me why this is done?
    Matt
  5. Wendell
    Jul 23, 2002
    96
    How do you get sonic benefits by rounded corners?
    Is the 3/4" and 1/2" the depth of the cut from the edge of the corners?
    I'm planning on rounding the edges of my sub, a 214L AA. I also used 3/4' MDF. I was afraid of cutting too deep and weakening the joints. Please advise on which cut is best for me.
    Thanks for everyones help!
  6. Chris Carswell
    Mar 5, 2002
    598
    It is a sub so no sonic benefits, all aesthetics on this one.
    Are you veneering or painting? I guess painting so go with the 1/2" roundover
  7. Brian Bunge
    Sep 11, 2000
    3,716
    Well, I prefer 3/4" roundovers, but it's just a personal choice. It'll work fine with 3/4"MDF.
