How to resize digital photo
Discussion in 'Computers' started by Dean_Jonesy, Apr 16, 2004.
  1. Dean_Jonesy
    Dean_Jonesy Agent
    Feb 14, 2003
    37
    I bought a nice 4.0 Megapixel camera this week and wanted to share photos on another website but it only supports 600 x 800 or smaller. Well, the smallest resolution on my camera is like 1200. I tried using IrfanView and it worked to a degree helping me post my pictures but they came back really pixelized. Is there a better way to do this to keep the original look of the picture without pixelation or shinking the picture size too small? Any IrfanView experts out there? I appreciate any help.
  2. Gordon Moore
    Gordon Moore Second Unit
    Nov 1, 2000
    340
    If you are using XP try the image resizer in the XP Powertoys:
    PowerToys
  3. Will_B
    Will_B Producer
    Mar 6, 2001
    4,731
    $30 on Photoshop LE will be the best money you've ever spent.
  4. Cameron Yee
    Cameron Yee Executive Producer
    May 9, 2002
    11,828
    720
    9,110
    Since 2006
    Cameron Yee
    Didn't your camera come with software of some kind?
  5. Kyle McKnight
    Kyle McKnight Cinematographer
    Mar 8, 2001
    2,504
    With Irfanview you can change the compression settings for the newly resized jpg....I don't go below 80 or 85%...and I save the original.
  6. Todd Hochard
    Todd Hochard Cinematographer
    Jan 24, 1999
    2,312
    Download Vueprint. www.hamrick.com
    The .jpeg recompression on it is really tight, and really clean, IMO.
  7. Dean_Jonesy
    Dean_Jonesy Agent
    Feb 14, 2003
    37
    Thank you all! I do have XP and I'll check out my Kodak software also. It is still so new. I appreciate your responses!!
  8. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    If you have Microsoft Office you can also use Microsoft PhotoEditor. It's an optional component, so stick your MS Office disk in and go to Add Components.
  9. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,449
    337
    9,110
    Cees Alons
    You can even use MS-Paint.
    (Double-)click the file to open it in Windows Picture and Fax Viewer (the default preview). Type CTRL-E or else click the icon at the bottom (almost) right, saying "Closes this program and opens the image for editing (CTRL + E)".
    In Paint, choose "Image" from the toolbar and then "Stretch/Skew..." (or CTRL-W). Now make sure to choose the proper percentage - and the same for horizontal and vertical (e.g. 75% both). Then save the image under a different filename.
    Presto!
    Cees
  10. JohanD
    JohanD Stunt Coordinator
    May 22, 2003
    180
    I use irfanview all the time and do not have any problems resizing. Typically I set the jpeg quality/compression to the highest it will go (100). A little bit larger file but it looks better. [​IMG]
  11. Christian Behrens
    Christian Behrens Supporting Actor
    Mar 2, 2000
    714
    110
    SF Bay Area
    Christian Behrens
    I concur. If you already use IrfanView, just choose a higher quality setting for JPG when saving.
    -Christian
