Jeffrey Stanton
- Feb 25, 2003
Hey Tumult Users:
I've got an Acoustic Visions/Stryke 5 cubic foot sub with a fried AV-15 in it. The Tumult I'm going to replace the AV-15 with is on the way, so I figure I'd better get an idea of exactly what I need to do to swap the drivers. Is it as simple as unscrewing the AV-15 and dropping the Tumult in its place?
Should I have the box sitting driver-side-up or sitting in the side-firing position when I remove the AV-15 and replace it with the Tumult?
Do I use the same screw holes for the Tumult that were used for the AV-15 (will the holes for the Tumult line up exactly with the AV-15 holes)? Or do I need to sink new holes?
What do I need to do to make sure the Tumult is sealed to the box (i.e., no leaks)? Will screwing it in be all I need to do?
Anything else I might need to know or watch out for?
Jeff Stanton
Jeff Stanton
