How to remove smell of cigarettes from amp? (1 Viewer)
AaronG
Hi Guys,
I just bought a used Bryston 3B sst (Thanks James!) The previous owner was a smoker, and I find that the amp smells like cigarette smoke. I have a non-smoking house hold and I've gotten a few complaints.
Does anyone know how to get the smell out of the amp?
Aaron
Brett DiMichele
Brett
Just tell the amp that smoking will stunt it's growth and
you should be okay.... :D
You might want to buy a couple cans of Fellowes PC Duster
from Wallyworld and take the cover off the amp and dust the
guts off.. That may help.. I have heard some guys will put
the amp in thier basement and let it play for a few days and
they say this helps air it out.. Or you could always hang a
Smelly Pine Tree inside (you know.. the car air fresheners)
Todd Alexander
Kick James butt for being a smoker, then, clean as much of the receiver as you can (which you probably already did). The remaining scent will disapear as time goes on. In a week it will be significatnly weaker. In a month it should be about completely gone.
The air duster idea is pretty good too, it may speed up the time you wait.
AaronG
Thanks guys,
I'll try the duster.
Bryston actually just recommended the same thing. They said I should use an air compressor at 80-100 psi.
Anyone know what psi the duster is?
Aaron
Chu Gai
It's got to be less than that, after all it can't fill a tire!
Another thought, aside from opening the unit and cleaning everything that's not critical, would be to place a charcoal filter or even briquet inside in a safe place to absorb odors.
Mark Dickerson
Aaron:
Move it to the basement, take the cover off and let a fan blow on it for about a week. Set up a couple of passive air fresheners next to it (the kind that is intended to "neutralize" smoke), as well.
It should be fine in a week.
phyllisbernhard
