How to remove car "emblems"
Discussion in 'After Hours Lounge (Off Topic)' started by Scott_lb, May 10, 2003.
  1. Scott_lb
    Scott_lb Supporting Actor
    Oct 7, 2002
    592
    I am interested in "renewing" my '97 Toyota Camry. I've always taken great care of it, however, I am now in the process of getting the 60k mile service done, changing the belts, etc. I am also fixing up some of the asthetic aspects of the car as well. The four gold emblems on the rear of the car ("Toyota", "(the toyota symbol)", "Camry", and "Le") are very faded, and I'd like to replace them. After popping the trunk, I haven't the slightest idea of how to remove them. I see many other cars on the road who have removed and/or replaced the emblems on their cars, and I'd like to know if I need to take it to a shop to have it done or if I can take care of it myself.
    Thanks!
  2. Tim Markley
    Tim Markley Screenwriter
    Jun 12, 1999
    1,279
    This is commonly called "debadging". Most of these badges are held on by glue. You can use fishing line and just 'saw' back and forth between the emblem and the paint finish to get it off and then use something to remove the rest of the glue. I think there's a product called 'goo gone' or something like that. I've never actually done it myself so I can't really be more specific.
  3. Shane Bos
    Shane Bos Second Unit
    Jun 15, 2002
    256
    there is a product called "Goo Gone". I have also seen "Sticky Stuff Remover". Lighter fluid usually works very well to remove residue, however I don't know what any of these products will do to the paint.
  4. Don Black
    Don Black Screenwriter
    Dec 11, 1998
    1,480
    Dental floss and a hair dryer work well for debadging. Be carefull with Goo Gone though to make sure it doesn't damage your paint job.
  5. Bobby T
    Bobby T Supporting Actor
    Mar 13, 2001
    583
    A heat gun or a very hot hair dryer. If there is any adhesive left use 3M adhesive, tar, and wax remover or you can get an eraser wheel that attaches to a drill.
  6. Matt DeVillier
    Matt DeVillier Supporting Actor
    Sep 3, 1999
    773
    use floss, a hair dryer, and goo gone automotive (or any other bug/tar remover)
  7. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    or if you live someplace warm, park your car outside for awhile, and let the metal get warm, and then use the floss/fishing line.
  8. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    Check out how much new gold emblems are going to cost before you remove the old ones, or better yet go back to the original chrome emblems.
    In most cases those gold emblems have a thin plating of real gold, and they are quite spendy to replace.
    If those emblems were "factory" they are real gold plated and very expensive to buy from the dealer. There is also a process by which the originally chrome emblems were gold-plated on the car at the dealerships, and this too resulted in a thin plating of real gold.
    Dealerships could either order cars with the gold emblems from the factory, remove the silver ones and replace them with factory supplied gold ones, or plate the originally chrome ones at the dealership with an electroplating kit.
  9. Scott_lb
    Oct 7, 2002
    592
    Thanks for the input. Yes, they are factory gold emblems. Also, I have checked out the prices on new ones. They run about $120.00 for a set. I'm not sure if I'm still going to do it, though.
  10. Clinton McClure
    Clinton McClure Casual Enthusiast
    Jun 28, 1999
    4,370
    400
    4,110
    Central Arkansas
    Clint
    I debadged my Celica last fall and it took about 15 minutes to heat up the adhesive with a hair dryer and saw it off with dental floss, then almost 2 hours to get the rest of the adhesive to come off. I used the 3M auto adhesive remover and used a finishing polish after I got all of the adhesive off.
  11. Jay H
    Jay H Producer
    Mar 22, 1999
    5,654
    32
    Pittsfield, MA
    Jay
    Dental floss and plain water for me. Fishing string would be stronger but I don't fish so I used dental floss. Now, my Toyota emblem is making a nice display on my computer monitor. [​IMG]
    Jay
