Mark Giles
- Aug 30, 2002
Simple...What's the best software to use if I wanted to securely connect and takeover my desktop on my home computer from either a laptop or from my work computer?
The only issue is that with residential DLS at home, the modem IP changes, so I have to email my home IP to work every day before work. And there's always the chance that Bellsouth will renew the IP during the day. It's happened to me b4.Do a google search for Dynamic DNS, I personally use no-ip, but I have heard DynDns is good as well.
HOWEVER! A vpn will provide you with a significantly higher level of security, as you won't have to open any ports to the internet at large, and all of your data will be further encrypted.Very true, although it limits you to connect from a Windows 2k or XP machine. Any other OS you have to download either microsoft's or a 3rd party VPN client.
You could do it in PCA9 but you had to hack the registry to get it to work PCA10 and above had it buried in advanced menus.Yes... this is what I was thinking of. In 10 it's really stuck down in there.
What's your analysis of VNC's security features?
quote:
I found VNC unbearably slow, but it works I guess.
Where you using dialup, broadband, leased line?
Broadband and 10Base-T (straight ethernet). Is there a new non-sloth version of VNC?
I have XP pro at home and use my 98 laptop from work to control it. It's very easy to set up on the XP box. All you need to do on the other machine (if not XP) is download the remote desktop client from MS.com.With an XP Pro host, you can configure it to host a web-based Remote Desktop session. You don't need the client software on the client computer, just a browser.
Could I control all functions on the HTPC (above) wake on lan, playback of all files etc. from a laptop or pc connected via Cat5 or wi-fi and play all the media through the big display and big sound ? (assuming of course that I have turned on the big display & receiver).I’m not up much on wake-on-lan (WOL) as I don’t use it at work and leave my PC's on 24/7. But the second part of your question. You could use remote control software from a laptop to control your HTPC. Any products listed here would be acceptable for internal network use.
Could I control all functions on the HTPC (above) wake on lan, playback of all files etc. from a laptop or pc connected via Cat5 or wi-fi and play all the media through the big display and big sound ?Not with remote desktop, because when you log in with remote desktop it logs you out on the system you are logging into, so all you would see is the login screen. I think you could probably do it via pcanywhere, though.
Not with remote desktop, because when you log in with remote desktop it logs you out on the system you are logging into, so all you would see is the login screen. I think you could probably do it via pcanywhere, though.I know this is how Terminal Services works on Windows Server. I though however that remote desktop was designed so that someone could control your computer to help the user with a problem. I have never run Remote Desktop personally so there is a good chance im wrong. Ill add that to my test list along with TightVNC.
I though however that remote desktop was designed so that someone could control your computer to help the user with a problem.That's Remote Assistance -- different than Remote Desktop.
