How to put form in a Subwoofer...
Discussion in 'Archived Threads 2001-2004' started by Peter Conn, Jan 7, 2002.
  1. Peter Conn
    Peter Conn Auditioning
    Dec 30, 2001
    8
    I am considering putting form into a Subwoofer to reduce booming... not having ever done this..
    How is this done?
    What kind of form should be used?
    I am looking to do this to a sony SA-WM40
    [​IMG]
  2. Greg Thomas
    Greg Thomas Second Unit
    May 3, 1999
    438
    I bought some Polyfil at the local arts and crafts store for my Sony sub. You can probably pick some up at K-Mart, Walmart or Target also. It'll only cost $5 or so.
    Unplug your Sony from the outlet. Take the front cover off the sub. Take out all the screws holding the sub in place. I laid the sub on the amp side with woofer facing up. You can set the woofer on the top without too much trouble. Be careful not to pull loose any wires.
    Buy the Polyfil that comes in sheets. Cut into the correct size to fit into each side of the cabinet. You can either use a staple gun or velcro strips or maybe even glue to hold the insulation in place. I think I used about 3 inches on foam on each side of the cabinet. Place the woofer back in the enclosure and insert all the screws.
    It took less than 10 minutes for me to complete. The boominess is definitely reduced at the sub sounds great.
    Good luck.
  3. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    What Greg recommends may help. However, note he says to line each wall. Don't just fill the thing with polyfil. It is not a good idea to stuff a ported enclosure.
  4. Mike_A
    Mike_A Stunt Coordinator
    Oct 7, 2001
    153
    so i've been meaning to put some foam in my SA-WM40 as well, but didn't know exactly what to buy. s it better to use something like acoustic "egg crate" style foam or something like polyfill or acoustastuff(tm)? I've got some old egg crate style foam (although who knows if it's "acoustic" foam) that was used to pack something or other - would that work?
  5. Peter Conn
    Dec 30, 2001
    8
    Thanks for all the advice, I am beginning to get the idea of what to do. I have noticed that you can turn down the level and Cut Off Freq which seems to reduce the boom considerably when playing music.
  6. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    Mike -
    Try it, nuttin' to lose.
    I think it may be too dense to give the same results as poly, but you never know with audio!
    - CM
  7. Brian Johnson
    Brian Johnson Supporting Actor
    Oct 21, 2001
    739
  8. Greg Thomas
    May 3, 1999
    438
    I actually lined the 3 bare sides with polyfil and left the side with the wiring and port uncovered. Made sure I was careful not to block the port. Sorry if I didn't make that clear the first time.
    The boominess is definitely reduced. It sounds great. Will probably buy a 2nd sub for my bedroom system when I find them on sale again.
