How to put Closed Captions on an Sanyo Z2 projector??
Discussion in 'Displays' started by Edgler Vess, May 20, 2005.
  1. Edgler Vess
    Edgler Vess Extra
    May 22, 2003
    24
    Hi
    I have a moderate hearing loss and need closed captions on my Sanyo Z2.
    Any advice would be greatly appreciated.
    It is really frustrating to keep asking my wife about the content of the dialog.
  2. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    For dvd you're pretty much stuck with the subtitles on the disc, if any. I have a few titles with no English subtitles, only cc and it doesn't work even on a regular HD ready rptv at anything other than 480i.
    For regular and HDTV, most all DirecTV HD boxes can do both analog cc for ntsc and the new digital cc for atsc signals.
  3. Gerald LaFrance
    Gerald LaFrance Supporting Actor
    May 28, 2002
    510
    Earth
    Gerald LaFrance
    Hi Edgler I was looking into getting this same Projector, How do you like it any pros or cons? It seems like a very good projector and since the Z3 came out it dropped $200.
    I am mainly gonna watch DVD's and HDTV!! THNX
  4. Edgler Vess
    Edgler Vess Extra
    May 22, 2003
    24
    Thanks for the reply
    Pros:
    Cheap, easily the best value in 16:9 projection available.
    Great DVI performance
    Lens Shift
    Cons:
    Just a decent performance right out of the box
    Prone to dust blobs
    Vertical lens shift doesn't give much latitude
    Component inputs seem to give a softer image as compared to the DVI
  5. Gerald LaFrance
    May 28, 2002
    510
    Earth
    Gerald LaFrance
    I have read about dust being a problem with LCD's is this easily corrected??
    How do you like the picture?? was it easy to setup as you said the performence was just decent out the box??
  6. Gerald LaFrance
    May 28, 2002
    510
    Earth
    Gerald LaFrance
    Bump THNX Edgler but Please a few more Questions? see proior post!! THNX AGAIN [​IMG]
  7. Edgler Vess
    Edgler Vess Extra
    May 22, 2003
    24
    The picture is great ... but get a DVD player with DVI
    Was it easy to setup as you said the performence was just decent out the box??
    Not very good out of the box ... but easy to setup.
    Just buy it !!!!
  8. Gerald LaFrance
    May 28, 2002
    510
    Earth
    Gerald LaFrance
    Hi I was going to use the DVI for HDTV!! the Componet on the DVD is NOT any good?? Or would I be able to have BOTH on the DVI thru the reciever??
    I am sold on this unit, I just had a few Questions THNX!!
    [​IMG]
  9. Edgler Vess
    Edgler Vess Extra
    May 22, 2003
    24
    Sorry ... don´t know ... but probably not .
