how to prove 480p mode?
Discussion in 'Archived Threads 2001-2004' started by JasonKrol, Dec 17, 2001.
  1. JasonKrol
    JasonKrol Supporting Actor
    Aug 19, 2001
    505
    Hello all,
    Im using the Toshiba 50H81 RPTV, and I recently hooked up Xbox. Im wondering if there is a way to know if the tv is actually in 480p mode? Is there a setting or something? Info buttton?
    Thanks!!
  2. MichaelG
    MichaelG Second Unit
    Jul 10, 2000
    322
    First off, that TV can never be in 480p mode, since it only displays 540p or 1080i. However, it will always be in 540p mode unless it is receiving a 1080i signal from the HD inputs on the back. Even if you pass this TV set a 480p signal it will upconvert it to 540p.
    So, I am assumming that an xBox can't output 1080i, therefore you are seeing 540p when you use it on tyou TV.
  3. Andrew Grall
    Andrew Grall Supporting Actor
    May 17, 1999
    645
    Actually, the X-Box CAN output 1080i, but there aren't any games out yet that support that feature...
    I would, however, be interested in knowing if there was a way to see what resolution the TV is at...
