How to organize cables?
Discussion in 'Gaming' started by Debbie E, Aug 3, 2003.
  1. Debbie E
    Debbie E Stunt Coordinator
    Feb 26, 2003
    82
    I have over 20 cables making a big mess. I plan to cut this down by doing wireless for the PC, laptop, and PS2 (XBOX Live does not recommend wireless).
    That still leaves over 20 cables. How do you keep your cables in check? Can anyone show pictures of their cable setup?
    Thanks! [​IMG]
  2. Allen_Appel
    Allen_Appel Second Unit
    Dec 13, 2002
    418
    I use Linksys for wireless Xboxing and it works just fine.
  3. Debbie E
    Feb 26, 2003
    82
    Right now I can't use wired or wireless since I can't connect through my DLink router and people at DLink CS are CLUELESS. I've wasted over two hours and still doesn't work.
    The XBOX people will help you set up a wired so I figured I'll ask them to help me set up wired and then just switch to wireless [​IMG]
    Anyone have any experience with a Dlink router?
    And what about the cables?
  4. Allen_Appel
    Dec 13, 2002
    418
    Sorry, my cables are a worse mess than yours, I'm sure. Going "wireless" added four wires to the mix!
  5. JohnE
    JohnE Supporting Actor
    Jan 1, 2001
    585
    This is the bane of HT and computing. If someone could come up a solution they would make a killing.
    I was just thinking about this the other day after moving recentely. I couldn't come up with anything to make it better.[​IMG]
  6. Jordan Raup
    Jordan Raup Stunt Coordinator
    May 3, 2003
    89
    Im trying to use Linksys Ethernet Bridge for XBOX LIVe, but do far it is not working. If any knows a trick or a tip to get it set up, pls drop me an e-mail @ [email protected]. Thank you!
  7. John Kilroy
    John Kilroy Stunt Coordinator
    Jun 30, 1997
    195
    Split flex tubing, available in black or white. You can buy it at Best Buy, or the same stuff at Ace Hardware for about a tenth the price.
