MichaelDDD
- Sep 29, 2003
- Mike
I purchased a cheapie 15" LCD to support my HTPC; i.e. when I want to play MP3s, I can navigate thru the LCD and not have to turn on the main display, which in my case is a projector.
In the instructions it says "Supports removeable base and VESA standard mounting arm for wall mounting."
I can see how to take the base off. And I can see four threaded inserts on the back of the monitor. This is obviously where the arm or whatever screws in.
I want to fabricate a wall mount. It doesn't have to move. I want it mounted on the wall, permanently. I'm doing this to avoid having to build/mount a shelf for it to sit on. Plus, it would look damn cool mounted on the wall. :thumbsup;
Anyone done this before? What is "VESA mounting standard?" I haven't taken a ruler to the mounting holes, but that's easy enough to figure out. What size are the mounting holes? Thread pitch? It's obviously metric (It's made in Asia and all PC hardware is measured in metric anyway) but I don't know much more than that.
Any experiences with this?
