How to manually change the DEFAULT BROWSER?
Discussion in 'Computers' started by NickSo, Feb 18, 2004.
  1. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    I installed WEATHERBUG yesterday, but found out it doesnt work with canada, and its full of ads!
    I try to uninstall it, but it has to go on the net to get access to a file. I have Firebird as my default browser, so not all the special funcionality of IE works. I want to make IE my default browser so i can uninstall this thing, i went into the TOOLS and checked "MAKE SURE IE IS THE DEFAULT BROWSER AT STARTUP" (something like that), but it doesnt check!
    Any way to change it manually?
  2. Greg*go
    Greg*go Supporting Actor
    Jun 14, 2002
    941
    To make IE the default browser is fairly easy...
    Start -> Control Panel -> Add/Remove Programs -> Set Program Access and Defaults (it's on the left side of the window) And go to custom... The rest is self-explanatory.
    Of course, this is assumming you are using XP. I forget if this works with other versions of Windows.
  3. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    Nevermind, got it working [​IMG]
    Thanks for the help
