Rick Simpson
- Aug 15, 2001
Does anyone have any info where i could order the supplies
to make my own RGB component cables and the how to,thanks
You can also save quite a few dollars on the tools. The Ideal industries stripper that Lowes sells will strip the RG6 perfectly for the Canare connector. Ideal also makes a crimp die that will do the center pins perfectly as well. I had to special order the die via Lowes though. The die was about 20 bucks. The stripper was 15. The stripper requires you to adjust the blades in it to strip is just right in all three places. Once you get them adjusted...YOUR IN THERE. Chris, I dont know if you saw in the cable thread at AVS that i posted this info for ya..
Do you happen to know the model # of the die for the center pins. When I was making cables before, that was the only problem I ever encountered.
Josh
