how to listen/feel below 30hz sound?
Discussion in 'Archived Threads 2001-2004' started by Yoon Lee, Nov 1, 2001.
  1. Yoon Lee
    Yoon Lee Stunt Coordinator
    Jun 16, 2001
    162
    Ok, how do I know if the system is pumping out below 30hz sound? Or, how do we know if the system is missing below 30hz sound? What am I supposed to hear/feel this low?
  2. John Cain
    John Cain Second Unit
    Nov 19, 2000
    359
    Once you hear significant sound below 30Hz, you will know it!
    If you are not hearing it, you will not miss it.
    Also it is rare for CDs or DVDs to have information this low, unless it is a movie effect, or a top notch music recording of organ music.
  3. Len Cheong
    Len Cheong Second Unit
    Mar 18, 2000
    372
    1. Rattling of household items - glass, heating ducts, etc.
    2. To be sure, put in a test tone cd and see. If your sub
    can't handle it, it will create a flapping sound. Test
    tone cds have specifice tone sweeps (e.g. 20-30 Hz).
  4. Han
    Han Second Unit
    Jan 13, 2001
    262
    Along with a tone generator, an SPL meter will tell you if your sub/speaker is putting out a signal below 30Hz. In Avia's LFE sweep, once it drops below 28Hz or so, I can't hear a thing, but my SPL meter still shows a reading.
  5. Tor Arne
    Tor Arne Stunt Coordinator
    Aug 17, 2001
    75
    Try Bjørk Vspertine track 8. It has some low 20s sounds. The Telegram album, track 10 has even lower bass, probably 20Hz. The Gorillaz album has some really low sounds. Track 7 begins with some about 30Hz sounds. Many other tracks on the Gorillaz album has short bursts of low frequencies. You can recognice them because they feel nice to hear. That's the best way to describe it IMO.
    I have a tone generator and I recognise the frequencies in case you wonder.
    TAH
  6. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    Buy yourself a cheap copy of AVIA that you can use to setup your a/v and also check the frequency response of your speakers and room. It will tell you exactly how low your system goes. Right now, mine is sadly audible down to only 24Hz but once I finish making the Maxcaliber Supernova, that should change to at least 15-16 Hz.
    http://webhome.idirect.com/~orange1
    My Favourite DVD's
  7. Rick Radford
    Rick Radford Supporting Actor
    May 12, 2001
    642
    Neil,
    Perhaps I missed it on my tests with Avia. But where does it tell you the frequencies? I've seen one place but it never goes below 20.xx Hz or so (always some decimal number).
    --RR
  8. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
