How to increase rolloff of subwoofer?
Discussion in 'Speakers & Subwoofers' started by MartyP, Apr 10, 2004.
  1. MartyP
    MartyP Stunt Coordinator
    Jun 5, 2003
    67
    I'm trying to help a friend with his subwoofer problem. His sub has a rolloff of 6dB/octave and seems to let too much upper bass/midrange(?) through. The sub has no bypass switch. Is there any way to increase the rolloff slope of the sub at 80 Hz using the low level inputs?
  2. Edward J M
    Edward J M Cinematographer
    Sep 22, 2002
    2,031
    Most speaker level connections on the subwoofer plate amp have a fixed 1st order high pass filter for the speakers, and a variable 2nd order (12 dB/octave) low pass filter for the subwoofer.
    I haven't ever seen a 1st order low pass filter on a subwoofer, but anything is possible, I guess.
    Regardless, if the subwoofer is playing too much mid range with a speaker level connection, then simply lower the frequency on the low pass filter.
    If you switch to a low level connection and set all the speakers to small and the sub to on/yes, most AVRs have a 2nd order high pass filter for the speakers, and a 4th order low pass filter for the subwoofer.
    If the sub is lacking a low pass filter bypass switch, then simply set the low pass filter control to its highest setting to avoid cascading the AVR and the subwoofer low pass filters.
  3. Paul_Wright
    Paul_Wright Auditioning
    Dec 6, 2003
    10
    Behringer makes a small 2-way crossover (CX2310?...not sure about the model #) that also includes a variable frequency 24db/octave mono sub output. You can pick them up on the net for about $80 new. The only issue is that the inputs/outputs are pro-audio XLR connectors. If you don't want to make adaptor cables, Parts Express sells inexpensive RCA/Phone/XLR adaptors.
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,208
    57
    9,110
    Katy, TX
    Wayne
    Marty,
    What Paul is saying is that your best bet is to insert an external, line-level outboard crossover between the receiver and sub.
    Wayne A. Pflughaupt
  5. MartyP
    Jun 5, 2003
    67
    Wayne:
    So an external crossover can be used in addition to the built-in crossover? Should the built in crossover be set to it's highest setting? Are the crossover slopes additive (6dB + external crossover's slope)? Sorry about all the questions...
    Marty
  6. ScottCHI
    ScottCHI Screenwriter
    Feb 21, 2004
    1,292
    does his pre/pro have bass management capabilities?
  7. John F. Palacio
    John F. Palacio Supporting Actor
    Jan 6, 2002
    575
    I have used a Paradigm X-30 external crossover successfully for that same purpose. I have it in series with the sub output of a Sunfire Theater Grand processor and use it both as a level control, phase control as well as to "tighten up" the upslope of the sub. Other external crossovers will work just as well. The output of the X-30 then feeds the power amps that drive the subs.
    You can use this scheme with a receiver as well. It will also work with a sub with built-in amp. You just feed the output of the external crossover to the sub.
