How to flip image?
Discussion in 'Archived Threads 2001-2004' started by Matthew Will, Jan 26, 2002.
  1. Matthew Will
    Matthew Will Stunt Coordinator
    Jan 6, 2002
    168
    Hello all,
    So I'm cheap. I bought one of those fresnel lenses to use on my 19" Toshiba TV to hopefully project a 100" image onto my wall. Problem is my tv doesn't like to be turned upside down. So instead of taking the tv to a shop to have them switch only 4 wire for 40 bucks, I would like to do it myself. My question is, has anyone ever done this before? I just took off the back of the tv and saw 4 different colored wires running from the bottom of the tv to the back of the tube. I can get pics for anyone that would like to help me. Please help me save 50 bucks and let me know how. Thanks. Matt
  2. Dan Wesnor
    Dan Wesnor Second Unit
    Apr 28, 1999
    389
    There are parts of the inside of a TV that are charged with thousands of volts long after the TV is turned off and unplugged. I wouldn't touch anything in there unless you know what you are doing.
  3. Cam S
    Cam S Screenwriter
    Jan 11, 2002
    1,524
    Ahmen to that.
  4. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    I'm not positive, but I think you'd need to rotate the yoke 180 degrees. Not really something for a novice to do.
  5. Jeffrey Noel
    Jeffrey Noel Screenwriter
    Sep 11, 2001
    1,533
    I agree, just pay the $40 and have a "pro" do it. That's just a wee bit less to pay than your life!
