How to disable Windows 2000 battery meter in Systray ?
Discussion in 'Computers' started by Marc Colella, Jul 28, 2003.
  1. Marc Colella
    Marc Colella Cinematographer
    Jun 19, 1999
    2,601
    Windows 2000 has it's own battery meter that can be disabled from showing up in the systray when the AC adaptor is plugged in - but I don't see any way of also disabling it when it's running off of the battery.
    I prefer to use IBM's "Battery Maximiser" meter, and hate the idea of having 2 battery meters showing up in the systray since it's overkill.
    Any way to disable the windows battery meter in all scenarios?
  2. Mike__D
    Mike__D Supporting Actor
    Dec 27, 2000
    617
    Right-click your desktop, choose Properties, select Screen Saver, click Power, then Advanced Tab. Clear the "Always show icon in taskbar" box.
    [Edit - just saw you said when it's not plugged in... not sure if this will work or not]
    Mike D.
