How to decrypt a folder?
Discussion in 'Computers' started by StephenA, Apr 14, 2004.
  1. StephenA
    StephenA Screenwriter
    Nov 30, 2001
    1,512
    I'm in kind of a dilemma here. My virus scanner System Suite says it can't scan the system volume folder because it's encrypted, yet it it detects 2 viruses in there when I run the All In One program. The virus scanner alone can't detect the viruses. I have Windows XP home edition on my computer. So ho do I go about decrypting it so I can clean it?
  2. Jon_Gregory
    Jon_Gregory Stunt Coordinator
    Jan 10, 2004
    225
  3. StephenA
    Nov 30, 2001
    1,512
    Thanks, but I still can't get it decrypted.
  4. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    Do you know what was used to encrypt it? Without knowing it will be basically impossible to answer.
  5. StephenA
    Nov 30, 2001
    1,512
    No I don't. Wish I did. What should I do then?
  6. Jon_Gregory
    Jan 10, 2004
    225
    Sorry, but if you did not encypt it with windows and you do not know how it got encypted, then you are just out of luck. Do you have other users on your computer? If you do, the folder has to be decrypted from the same user that encypted the file. Try logging onto your administrator account by booting up in safe mode, and then try decrypting it with the info I gave in my earlier post.
    Other than this, the file will not be able to be decrypted.
