Shawn O
- Jan 31, 1999
Could someone please tell me how to correctly "daisy-chain" two sets of speakers?
Thank you,
Shawn
Thank you,
Shawn
No wire them in parallel.Before doing this, make sure they are not 4 ohm speakers or you will have one hot amp.
But for better sound quality, and no risk, get separate amps to drive multiple rows of surrounds. Everyone is recomending it, so if you can afford it, do it. Either a 2 channel amp with A/B speaker outs (4 speakers from 2 preouts),A 2 channel amp with A/B speaker outs IS NOT a separate amp for each speaker. The A and B speaker outs share the same amp channels. They are ususally wired internally in the receiver (or amp) as the equivlent of being wired in parallell. They are intended to be used in as either A or B, not both at once.
