BrandonL
- Dec 12, 2000
So I just made a sub out of MDF. What is a good way to make it nice looking. I want it to be black. Can you guys give me some options and pricing? Its a 15inch cube. Thanks.
You do not have to sand the plywood before applying the laminate. You don't even have to fill the screw holes if you have any. Just make sure the surfaces are free of dust before applying.
If you're using the .020"-.030" postforming laminate you do. Any imperfections will show through. The thicker stuff will not.
Ken Cline - Home Theater Fanatic
[email protected]
Friends Don't Let Friends Watch Crap!
www.dvdtracker.com/~kencline.asp
