How to convet 16x9 video to 4x3 letterbox for VHS?
Discussion in 'Archived Threads 2001-2004' started by Yumbo, Aug 17, 2002.
  1. Yumbo
    Yumbo Cinematographer
    Sep 13, 1999
    2,227
    Hi,
    I shoot all my DV in 16x9 mode.
    I need to convert it on my Mac to 4:3 letterbox for my relatives who use VHS.
    any ideas?
    thanks.
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    Use Adobe After Effects or a similar program to unsquish and scale it down to fit in a 720x480 frame
    You can probably do the same in Premiere, though it takes a lot more steps.
  3. Mike_G
    Mike_G Screenwriter
    Jun 1, 2000
    1,477
    14
    Mike
    What app are you using?
    Mike
  4. Yumbo
    Sep 13, 1999
    2,227
    I've got iMovie and iDVD.
    I can get Final Cut and DVD Studio.
    cheers
  5. Ken Chan
    Ken Chan Producer
    Apr 11, 1999
    3,301
    If the camera does true 16:9 (instead of simply masking off part of the frame) the simplest thing might be to use DVD Studio Pro to make a genuine 16:9 anamorphic DVD. Play it back on a regular DVD player in 4:3 letterbox mode and tape that onto VHS. This has the added advantage of also getting a DVD out of the process.
    iDVD does not do 16:9. You should be able to use iMovie to capture the DV and do edits; everything will look squished, but that shouldn't affect the end result. DVD Studio Pro includes the QuickTime encoder, which will encode from DV to MPEG-2. It uses a fairly high bitrate, so you won't be able to squeeze a lot of video onto a disc.
    //Ken
  6. Mike_G
    Mike_G Screenwriter
    Jun 1, 2000
    1,477
    14
    Mike
    Final Cut Pro and DVD Studio Pro will do the work for you.
    Mike
