How to convert a QuickTime file to mpeg?
Discussion in 'Computers' started by George_fsf, Sep 8, 2004.
  1. George_fsf
    George_fsf Agent
    Jun 24, 2003
    33
    Hi, I have a Quicktime video on my computer and would like to convert it to mpeg in order to burn it to a cd.
    Is there any program that can do this?
    Thanks.
  2. Jeff Jacobson
    Jeff Jacobson Cinematographer
    Dec 24, 2001
    2,116
    Do you want MPEG-1 or MPEG-2? Are you trying to make a VCD, or an SVCD?
  3. Rob Gardiner
    Rob Gardiner Cinematographer
    Feb 15, 2002
    2,950
    You can burn Quicktime onto a CD just as easily as MPEG.
    If your goal is MPEG-1, the free version of TMPGEnc should do the job. If you want MPEG-2, you will need the full version.
  4. George_fsf
    George_fsf Agent
    Jun 24, 2003
    33
    Thanks, yes I'm trying to make a VCD.
  5. Jeff Jacobson
    Dec 24, 2001
    2,116
    The free version of TMPEGEnc, as Rob suggested, can convert video to MPEG-1, which is what you need for a VCD. I've never tried it with Quicktime files before, though, so I'm not sure if it can handle them or not.
    Also, your CD burning software might be able to encode the files (to MPEG-1) for you.
  6. Chris
    Chris Lead Actor
    Jul 4, 1997
    6,788
    BTW, if you have Nero Ultra, it will do it automatically for you in assembling your VCD [​IMG]
