daaro234
- Jun 19, 2012
- ada
guys thank you for everything.. If it was up to me I would go with 12 gauges ..But They already bought it 14 gauges..I installed the cables .these were inwall cables.. here is the cable that they bought pls take a look at the link http://www.amazon.com/Monster-14-Gauge-2-Conductor-In-Wall-500-Foot/dp/B00009V3RP/ref=sr_1_1?ie=UTF8&qid=1341381331&sr=8-1&keywords=Monster+Cable+CI+Pro+14-2%2F500+14-Gauge+2-Conductor+In-Wall+Speaker+Cable+%28500-Foot+Spool%29
as you see the link above , for some reason I did not like the cable .. the cable did not seem to me a strong and durable..I mean , as if , it might spark a fire at any moment .I hope I am wrong.. and the other problem is the last 35 feet of the very narrow attic in -wall installation..in these section , all wires touching each other they do not have distance from each other ..they are like adherent to each other ..the attic is extremely hot ..I was gonna die there while installing the cables ..its like oven..that heat is scaring me ..attic is already hot and plus ,cable's resistance (because its a long run , like 90 feet wiring with 14 gauge cable ) whats gonna happen ??
in the attic , cables are like this picture below.
(this picture is sample but mine looks like exactly like this..)
there is no way I can make something different , because its in wall and inwall wiring is so hard .even if the cable is an inwall cable , should I put them in to the conduit pipe ? if the answer is YES , should I put every single cable in a different conduit pipe ?
(oh god that would kill me ! )
what do you think my friends ? I don't wanna burn my sister's house..pls help again.. thank you so much ..
