how to connect a BFD DSP1124
Discussion in 'Speakers & Subwoofers' started by Alain.P, Aug 5, 2004.
  1. Alain.P
    Alain.P Extra
    Aug 28, 2003
    22
    Good morning all,
    I just bought a DSP1124 and after reading the manual i am unsure about how to connect it to my system.
    I have an Outlaw 771 amp with a 950 pre, and only one sub connected thru the LFE.
    How do i connect the DSP1124 to be able to equalize my sub
    Thanks in advance
    Alain
  2. PaulDA
    PaulDA Cinematographer
    Feb 9, 2004
    2,700
    99
    4,110
    St. Hubert, Quebec, Canada
    Paul
  3. Alain.P
    Alain.P Extra
    Aug 28, 2003
    22
    Yes i know this site but it does not say much about how to connect the 1124 to a home theater
  4. Lee Carbray
    Lee Carbray Second Unit
    Oct 23, 2002
    308
    Huh? did you read this section?
    Basically from your prepro run the LFE to either the left or right input on the BFD and then the corresponding output to your sub. You will notice the BFD does not have RCA type connections. That is why you need the 1/4 inch adapter. Here is an example of one.Adapter
  5. Wayne A. Pflughaupt
    Aug 5, 1999
    6,222
    59
    9,110
    Corpus Christi, TX
    Wayne
    If you’re like me and don’t like to use cheezy adapters, you can pick up cables with 1/4”-RCA ends at any guitar shop.
    Wayne A. Pflughaupt
