How to connect 2 coax cables w/a 3rd?
Discussion in 'Beginners, General Questions' started by Tim Holyoke, Jun 11, 2004.
  1. Tim Holyoke
    Tim Holyoke Second Unit
    Nov 6, 2002
    268
    Basically I need to add a 3rd coax to fill a gap between 2 others (don't ask, long story). It's only about a 5 foot gap. Other than the obvious 5' of coax, what else would I need? Both ends of the cables I'm dealing with have the normal screw on connectors on them (dunno what they're even called). Thanks a lot for any help!
  2. Mike_J_D
    Mike_J_D Stunt Coordinator
    Mar 3, 2003
    213
    You need two barrel jack to connect the 5' piece of coax in with your other 2. Everything you need can be found at Radio Shack.
    Hope that answers your question.
  3. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    they look like this.
    [​IMG]
  4. Mike_J_D
    Mar 3, 2003
    213
    Good call on the pic Ted[​IMG]
  5. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Big suggestion: use pliers/wrench to tighten the "F" connectors onto the barrels. The number 1 cause of poor video quality is loose connectors.
  6. Jeff Martin
    Jeff Martin Auditioning
    Jun 10, 2004
    10
    Why not just buy a longer piece of coax?
  7. Tim Holyoke
    Nov 6, 2002
    268
    Thanks for the help guys, I got some, they work great. The reason I couldn't get a longer piece of coax was because of where I had to ground it at.
