Yeto
- Aug 12, 2003
What would be the best way to compare separate component home theater sound system watts versus HTIB system watts given the way (rms, peak power, etc.) different companies rate wattage?
I just finished reading an article -- bittersweet.ondragonswing.com/005615.html -- that, generally speaking, says that most HTIB systems use class AB amps and that a class AB amps output is 50% efficient. The article goes on to say to calculate the power draw numbers of the amp in watts and divide by 2 to get the approximate true power output of a HTIB system when comparing to a separate component system.
I was wondering if the experts on this forum would agree with the article?
Yeto
Yeto
