How to clean CD changers?
Discussion in 'Playback Devices' started by Cagri, Oct 30, 2003.
  1. Cagri
    Cagri Second Unit
    Dec 18, 2002
    415
    110
    I have a Kenwood 200 disc changer which gets too much dust inside. When I replace discs, I see that the discs themselves are getting too much dust too. Is there a way to clean these changers? Will the lens cleaning brush CDs work ? Ty.
  2. ChrisHeflen
    ChrisHeflen Supporting Actor
    Sep 9, 2002
    912
    If it is past the warranty, take the cover off and blow it out.
    Don't forget to:
    Stand on a rubber mat and use a ESD wirst strap and be in a clean room when your doing it. Use only those mechanical arms in the plexiglass box to handle it. [​IMG]
    I just took the cover off of mine and blew it out. It was past the warranty and it still works after 12 years.
