how to clean a DVHS deck?
Discussion in 'Playback Devices' started by JeremySt, Jun 21, 2003.
  1. JeremySt
    JeremySt Screenwriter
    Aug 19, 2001
    1,770
    14
    Jeremy
    Im getting severe pixilization and picture drop out on a JVC DHVS deck. Should I use a normal head cleaner? Whats the best way to cure this problem?
  2. Reginald Trent
    Reginald Trent Screenwriter
    Feb 18, 2000
    1,313
    I preface this by stating I don't own a DVHS deck. That said, I would imagine the cleaning procedure would be similar if not the same as a VHS or SVHS deck. Thus, I would assume you could use a regular cleaning tape. If you don't have one simply use/play a regular tape preferably one that was recorded in the six hour mode, do so will clear your decks heads also.
    Play the 6 hr tape from start to end.
  3. JeremySt
    Aug 19, 2001
    1,770
    14
    Jeremy
    actually, I was always told the best way to clean a regular vhr was to run a head cleaning tape for about 10 seconds each usage, then throw the cleaning tape away once it was used up. Why would you run the whole tape? it would be dirty the next time you used it.
  4. Reginald Trent
    Feb 18, 2000
    1,313
    You misunderstood, I'm referring to the a regular tape that was recorded in the 6hr. mode.
  5. Darryl.K
    Darryl.K Auditioning
    Jun 28, 2003
    That is a known flaw with JVC 30K decks.
    Checkout www.avsforum.com
    and look for
    The 30K "Fix" - Official Thread
  6. Jack Briggs
    Jun 3, 1999
    16,738
    129
    But, Darryl, Jeremy came here to HTF with his question, and there are a number of members who own the JVC 30000.
