How to change impedance? (1 Viewer)
Joenco
Hello all,
Is it possible to change the impedance of a speaker from 4ohms to 8 ohms by placing a resistor in between? I know I can place 2 speakers in serie so that 2 four ohms speakers in serie have a total load of 8 ohms. Is it possible to get the same with one speaker and a resistor or something else?
Of course I don't want to lose audio quality.
A second question on the same subject.
My kenwood receiver asks for a speaker load of 6-8 ohms. What will happens if I attach speakers with 4 ohms impedance? Will this destroy the receiver or will I only lose audio quality?
Thank you,
Joenco
Brett DiMichele
Brett
If your reciever specifies the lowest impedance that it can
drive is 6 ohms then running a 4 ohm speaker will lower the
impedance past the safe limit and it could (and probably
will damage the speakers first.. then eventually the amp)
The lower the Impedance the more freely power flows out of
the amp, more power flows out than the amp can deal with
and you create a ton of heat that can damage the Fet's and
Resistors and Capacitors and you will cause the amp to send
a clipped signal which will destroy the tweeters in no time
short..
2 4 Ohm Speakers wired Series is 8 Ohm, 2 4 Ohm Speakers
wired Parallel is 2 Ohm.
David_Stein
David_Stein
you would have to find a hell of a high power resistor to be able to use it in series with a speaker, because i think most of the ones ive ever seen are quarter watt resistors.
NHCondon
