Ted Lee
- May 8, 2001
hey all -
i have the onkyo m-282 amp. it's curently hooked up to an adcom gtp-500 pre-tuner.
the back of the amp has an input-level adjustment (which i thought was kind of weird ... i would prefer no adjustment at all). according to the manual, they say you should crank it over all the way to max.
now that sounds like a good idea, but i've always been hesitant to "push" any elecronic adjustment (input, bass, treble, volume, whatever) all the way to max. it just seems to stress out the component and degrade the sound.
that being said, whenever i keep the amp at max, i can barely turn up the volume on my pre-tuner (which is kinda of cool, but kind of annoying).
so, after all that, my question is how do you all think i should adjust the amp? right now i have it about 3/4 of the way up.
thx,
ted
thx,
ted
