How SQUARE is a SQUARE room? (1 Viewer)
Phil de Bruin
Okay - so if a room is perfectly square, or have one dimension exactly twice another - you may encounter resonances that may colour the sound. But just how 'perfectly square' does a room have to be?
Are we talking within a half a foot? An inch? What about if the room in question is pretty god damn square, but the wall protrudes in the middle due to a fireplace? How much difference is that going to make?
Comments!?? :)
/nightdog35/images/filmreel.gif
John Desmond
The closer you get to "square" the worse will be your problems. Same thing with multiple dimensions being multiples of each other. So a room that is 8*8*8 will be real bad. Since we're talking about long wavelengths, I would think the 8* 9*8 isn't going to be much better.
Dustin B
The room doesn't have to be square or have one dimensione exactly twice the other. Any rectangular room will have 3 axial room modes (plus a bunch of others I don't understand yet). The reason square rooms are said to be the second worst possible shape (cube being the worst) is now two of those 3 axial room modes are the same, resulting in one frequency and it's harmonics being boosted or cut twice.
Richard Greene
Example for 18' x 16' x 8' room
showing axial room modes up to 80Hz.):
565/18 = 31Hz (and 31Hz. x 2 = 62Hz.)
565/16 = 35Hz. (and 35Hz. x 2 = 71Hz.)
565/8 = 71Hz.
Assuming room modes are 5Hz. wide there is the potential
for boomy bass at these frequencies:
29 to 33Hz (31Hz. mode)
33 to 37Hz. (35 Hz. mode)
60 to 64Hz. (62Hz. mode)
69 to 73Hz. (71Hz. mode)
Analysis:
The 31Hz. and 35Hz. modes are adjacent modes that may sound like one broad bass frequency peak from 29 to 37Hz.
The two 71Hz. modes are stacked = potential bass boom
The 62Hz. and 71Hz. modes are close enough so
they may sound like one broad bass frequency peak from
60 to 73Hz.
SaeCleaningService
