how should i upgrade my rears. adp 370 or mini monitor
Discussion in 'Speakers & Subwoofers' started by dajaga, Jul 24, 2003.
  1. dajaga
    dajaga Stunt Coordinator
    Jun 4, 2003
    86
    hy im going to upgrade my mircos. which would be the best upgrade i dont like the sound of them so they are the first to go. should i use the adp370 or the minimonitor. i only have a 5.1 system. money is no factor. or how do the towers sound as rears
  2. Steve Lucas
    Steve Lucas Stunt Coordinator
    Aug 12, 2002
    163
    It depends on what type of surround sound you prefer. A direct speaker, like the mini's or towers will be more localized, while the "quasi" Dipoles of the ADPs are more diffuse and seem to disappear more. I personally have the ADP's and I'm still not sure which ones I like best. The ADP's need to be mounted directly to the sides of the prime seating position so that you sit in the null area of the speaker. The direct speakers are a little more flexible when it comes to location. If you have the room for them, I think the towers wold sound awesome as surrounds.
    Steve
