How should I set my DVD player if I have a TV that does the "Anamorphic Squeeze"?
Discussion in 'Archived Threads 2001-2004' started by Chris Rock, Aug 31, 2001.
  1. Chris Rock
    Chris Rock Supporting Actor
    Jan 10, 2001
    710
    With all these terminologies floating around (3:2 pulldown, anamorphic widescreen, 16:9 enhanced, Progressive Scan, etc), I get a little confused when setting things up.
    I have a HD Ready TV with an "auto 16:9 enhanced" mode, and I have a progressive scan DVD Player (one of the new JVC DVD-A progressive-scan models). In the setup menu for the DVD player, I can tell it what kind of display I have. One of the options is 16:9, one is 4:3P+S, and one is 4:3LB. I figured since my TV was actually 4:3 (Sony WEGA 36XBR450) that I should choose 4:3LB. However, since the set has an auto 16:9 enhanced mode, should I set the DVD player for a 16:9 display? What will happen if I am watching non-widescreen materials? (God forbid.)
    Anyone have this TV (or similar) and a progressive scan DVD player? How is yours set up?
    "You advance yourself only by my good graces."
  2. Brajesh Upadhyay
    Brajesh Upadhyay Supporting Actor
    Jul 11, 1998
    787
    110
    Select "16:9" as TV Type in your DVD player setup.
  3. Kevin P
    Kevin P Screenwriter
    Jan 18, 1999
    1,439
    Set your DVD player to 16:9. Since your TV does the squeeze automatically, you'll get the enhanced resolution everytime you pop in an anamorphic DVD.
    When watching non-anamorphic material, the TV will automatically switch to 4:3 mode. So you don't have to do anything at all, once the player is set to 16:9.
    KJP
  4. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    If you do not select 16:9 on the DVD setup, the auto squeeze will not happen.
    The default is still 4:3, and the compression only happens when 16:9 material is detected. I have a non-XBR WEGA and it works like a charm.
    All progress is based upon a universal, innate desire on the part of every organism,
    to live beyond it's income.
    ITRCA ** Speedring (sorry, car guy)
    [Edited last by John Garcia on August 31, 2001 at 02:59 PM]
