Dougj43
- Apr 8, 2007
- Doug Johanningsmeier
First off I have been a two channel sound guy. Had to remodel after a pipe burst and decided it was time to get into more of a home theater. That is, decided two days before the drywall was to be hung. I ran heavy line for front R/L speakers and a decent line for front center. Included cable feed to component area and the Plasma. Included an extra two-wire line just in case. Thought to add a/c power behind the Plasma and plenty in component area and even one for a Sub Woof although the Kindel PLS-A speakers with Aragon amp provide lots of bass. Ran rear lines for back R/L speakers. After paying for advice I ran a HDMI cable $$$ from the area of components to the area of what expect to be a large Plasma. Opted not to run the intended rear HDMI line for projector because $$ 50 ft run. Also thought about viewing distance and decided to focus on sound and just the Plasma. Here is the question. Now the Drywall is up and about to be sanded and all that pretty wire that my electrician ran like a swiss watch maker is on the dark side. In looking for equipment I have gotten a quick education on where HDMI is or is not at yet. Wanted to use a Aragon Stage one pre/processor and, yes it was made five years ago when HDMI was not.
Sound will be ok with the Stage one and 2007 power amp but wish I had thought to add two more side speaker lines. With older components like the Stage one how screwed am I with no other feeds to the area of the Plasma then the HDMI cable? Is there a easy way to use the HDMI line to carry signal from my processer or should I make the Drywall guys happy who said "it's only your money" and add more component lines to the Plasma for use until HDMI components (using 1.3) catch up to cable manufactures.
Signed PPPPPP
Prior Planning Prevents Piss Poor Performance.
Signed PPPPPP
