How much would narrower baffle affect HF response? (1 Viewer)
Pete Mazz
I just tested a new kit I picked up. The original plans had a 9 1/2" baffle with a 1 1/2" rad on one corner and a 3/4" rad on the other. Throwing together a test box of 8 1/2" width with square corners yielded a response that was 10 dB down at 1.2 kHz to 10 kHz. Would the difference in baffle width account for this much attenuation?
Pete
ThomasW
Pete
What's the XO point and does it have baffle step compensation?
How did you measure, MLS, Sine wave, Nearfield, GP?
Pete Mazz
I think I figured it out. When I went to put the second Xover together, to triple check myself, I noticed a resistor that was supposed to be 5 ohm, marked .5 ohm. Checking the resistor confirmed it. A call to PE and they are sending the replacements. Right part#, wrong part! You think Mills would mark a .5 ohm as 0.5 ohm, Oh well.
Will let you know how it goes.
Pete
vasyear
