how much to fill the box?
Discussion in 'Archived Threads 2001-2004' started by Philip_G, Feb 7, 2001.
  1. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    How much polyfill do you think I'll need? I'm using a shiva in a 2.2 or so sealed box, I'm planning on using about an inch all around all surfaces on the inside, do you suppose this will be sufficient?
  2. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    Go for 50% fill rate, which would be half a pound for every cubic foot of volume (about 1 pound of polyfill). If it doesn't tighten up the sound, add in another 50% (for a total of about 2 pounds of polyfill). Experiment with the fill if you're adventurous. You can get the polyfill at fabric stores or even Wal-Mart.
    PatCave ; HT Pix ; Gear ; Sunosub I + III ; DVDs ; LDs
  3. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    cool, so about 2.5 pounds should do me. [​IMG]
    the sub's on backorder so I have plenty of time to obsess about it. Here's the cabinet (it's one of the ones MCM sells, not too bad at all for the cost) if nothing else it makes a nice end table for my chair [​IMG]
    [​IMG]
    [​IMG]
