How much overscan is acceptable?
Discussion in 'Archived Threads 2001-2004' started by Dave H, Nov 29, 2001.
  1. Dave H
    Dave H Producer
    Aug 13, 2000
    5,578
    207
    9,110
    Using Avia, I'm at about 5% overscan (6% on the left side of screen). How much is "allowable" and how do I fix it?
  2. Ron-P
    Ron-P Producer
    Jul 25, 2000
    6,284
    7
    Ron
    3-4% is good, but no less than 3%.
    Adjusting it will depend on what type of TV you have and will most likely need to be done thru the service menu.
    Peace Out~[​IMG]
  3. Eliab
    Eliab Agent
    Mar 18, 2001
    37
    Dave,
    5% all around should be the minimum that you should aim for. Like Ron, I like to shoot for around 3-4%. Often times, anything below 3% will reveal all sorts of junk.
    Eliab [​IMG]
  4. Dave H
    Dave H Producer
    Aug 13, 2000
    5,578
    207
    9,110
    Does the service manual explain how to change this typically?
  5. Andy L
    Andy L Stunt Coordinator
    Nov 26, 1999
    101
    I have 3% top and bottom and 5% on the sides. Trying to go any less on the sides really distorted the geometry.
    A service manual probably won't tell you step by step how to do. However, it will identify the values that you have to change. For my Panasonic they are all grouped under pincushion adjustments.
