Dustin B
- Mar 10, 2001
Answer, $14.95CDN.
I'm writing this in hopes you fine folks will pity me and tell me I'm not a moron, I'm just a little slow sometimes :b
I feel soooooo stupid right now
On Sunday I bought some sticky clips to clean up my runs of speaker wire. I pulled my equipment appart and cleaned it all off while I was at it. Then I put it all back together. DSS receiver wasn't working. Try it on a different cable in the house still doesn't work. Try a different receiver on my cable works. Hmm, tuner must be gone (everything else worked fine including watching shows I'd already recorded).
Phone Bell (I'm 6months out of warranty on a 5100 PVR). $150CDN plus $14.95CDN shipping to exchange mine for a refurb. Ok guess I have no choice. Lets do it.
Refurb arrives today. Hook it up, no signal. What the hell Go look again, I've plugged the cable from the dish into the RF antenna input (a total of 4 times now on two different receivers :frowning: ). Hook mine back up properly, works fine.
So there you have it, $14.95CDN (oh and a $150CDN until I get it refunded) to find out I'm a moron :b
