How much distance between front speakers?
Discussion in 'Archived Threads 2001-2004' started by Marshall Sander, Apr 17, 2002.
  1. Marshall Sander
    Marshall Sander Stunt Coordinator
    Mar 1, 2002
    71
    Just wondering what is the ideal distance between my front left and right speakers. The speakers will be placed on either side of a 36" television. There will be a center speaker on top of the tv. How far apart (or how far from each side of the television) should the front speakers be?
  2. ChrisMatson
    ChrisMatson Cinematographer
    Dec 14, 2000
    2,181
    Check out this informative link from Dolby. This is in PDF format.
    Basically, about 45 to 60 degrees apart from your listening position. The Center and mains should all be equidistant from the listening position.
  3. Ron Shaw
    Ron Shaw Stunt Coordinator
    Dec 4, 2001
    142
    The old rule of thumb was that the distance between speakers is the same as your distance from them (which comes out to 45 degrees). That was for stereo. With a center channel, you can probably spread them a little more.
