how much braceing do i need?
Discussion in 'Archived Threads 2001-2004' started by Bryan Michael, Jan 4, 2003.
  1. Bryan Michael
    Bryan Michael Supporting Actor
    Mar 2, 2002
    564
    i am bulding a 700l box with is 48in X 48in X 21.5in with is my outside mesurments. i am dubleing up the front pannel of the box for strenth. here is my questons how much internal braceing do i need? i was thinking of 2 from front to back with the box olny 22 in tall.
  2. zane
    zane Stunt Coordinator
    Oct 21, 2002
    104
    you may want to also put a side to side brace also
  3. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    [​IMG]
    This is 'adequate' bracing for a 160L sub that's 18" wide, 29" tall, 35" deep.
    You might want to add more bracing to your design since it's roughly 4 times bigger
  4. Bryan Michael
    Mar 2, 2002
    564
    wow how much do that weigh? i was trying to olny use 2-3 sheets of mdfb it looks like you used 4. or i was thinking of using 2 in strips of mdfb to make my braices and make a rib all the way around the box.
    bbbbbbbbbbbbbb
    bb__________bb
    bb__________bb
    bbbbbbbbbbbbbb
    or something like that. it would be 2 in thick.
  5. ThomasW
    Nov 6, 1999
    2,282
    Don't know the exact weight but it's well over 300lbs.
    You really should use doubled MDF on all the exterior surfaces. Then at the very least create a bracing arrangement similar to that shown in the larger Adire Audio designs.
    It's always a good idea to use the bracing to tie the top to the bottom and the sides to each other
  6. AlexKunec
    AlexKunec Stunt Coordinator
    Mar 9, 2002
    161
    With those dimensions, why dont you build a LABhorn?
  7. Bryan Michael
    Mar 2, 2002
    564
    i am not that good at bulding things. and i dont know if i can use the av15 in the lab horn design.
  8. Eric Massey
    Eric Massey Agent
    May 21, 2001
    31
    braces are sometimes hard to cut to the precision needed for a good fit. I just built a box 21" x 21" x 21" and I only used one top to bottom to side to side brace in the middle of the enclosure. The speaker sounds fine and there is no noticeable flexing.
    With your size box, I would brace the long sides twice, like you suggested yourself. Also, in my opinion the less power you use, the less bracing you can get away with.
  9. Bryan Michael
    Mar 2, 2002
    564
    i amgoing to throw 500 wats rms on each
