How much better is prologic 2 compared to logic 7.
Discussion in 'Archived Threads 2001-2004' started by Tan_U, Oct 7, 2001.
  1. Tan_U
    Tan_U Stunt Coordinator
    Sep 17, 2001
    67
    I've just ordered a Harmon Kardon AVR110. There new AVR120 is the same thing except it has Prologic 2 wheres the AVR110 has logic 7. Is it a big difference in performance?
  2. Randy G
    Randy G Second Unit
    May 18, 2000
    460
    Not sure, but I believe that the Logic7 in the HK isn't quite the same version as in the Lexicon series. That being said, I'd guess that DPLII is probably a bit better for 5 channels. If one has a full 7 channel Logic7 implementation, that would be preferable to just 5.
    As for Lexicon Logic7, the consensus seems to be that if you're using 5 channels, Logic7 is pretty close to DPLII, but with 7 channels, it's better...makes sense to me. Now if DPLII were scaled to 7 channels with appropriate delays and volume settings, THAT would be a cool CHEAP Logic7 substitute.
  3. Stephen Dodds
    Stephen Dodds Second Unit
    Aug 29, 1998
    354
    Randy is correct. DPL2 is as good as Logic 7 (IMHO) over 5 channels. A 7 channel system is better again.
    The H/K version of L7 in their older receivers is not the full Lexicon version, but I understand the new H/Ks are better.
    Personally, I'd get the DPL2 one.
    Stevge
    Steve's Toys
